AURISTR01 8 Posted December 7, 2012 Share Posted December 7, 2012 Sold my Auris a week ago, have to say one of the most reliable car I ever owned.Other than the usual service items Oil & filters brake disc & pads didnt cost me a penny.Cleaned the EGR Valve twice in 20k miles as it clogged first at 59k then 72k sold it at 79k. Was kind of worried with the new model coming out the value would drop & mileage getting higher found a low mileage civic only done 48k better resale cost for future.MPG LocalSummer - 38-39Winter - 35-36Motorway - 45-50 possible£40 would get 220 milesMods: HID kit as the standard lighting was poor.Brakes: annoying squeal,& steering wheel clonkHandling: 5/5 never once had understeer or felt bodyroll3 MOT straight passInterior spacious but can be bland compared to other rivals IMO.New car is a civic 2.2 I-CDTI hope it holds up as well as the Auris, better toys Sat nav, bluetooth, cruise control, climate control, etc & seems more refined & fairly decent mid range power. Currently averaging 39MPG local thats winter.Would like to say on a final note this forum has been helpful & supportive, Thanks for all your responses in the past. Take it easy! Quote Link to post Share on other sites
Mistermena 95 Posted December 8, 2012 Share Posted December 8, 2012 Hope all goes well with the new motor. Just keep a keen eye on the Oil level (As they are known for drinking the stuff) and the exhaust manifold as they can crack! But otherwise they are a lovely car. My brother-in-law has the 4x4 with the same engine... Quote Link to post Share on other sites
Uncle Buck 92 Posted December 8, 2012 Share Posted December 8, 2012 The other car I was looking at before deciding on the Auris was the model you've just bought. I only really chose against the Honda because it was another £1500 for the same model year !Good luck with it :) Quote Link to post Share on other sites
Rob77n 0 Posted December 9, 2012 Share Posted December 9, 2012 What problems were you having that you cleaned the egr valve? Quote Link to post Share on other sites
AURISTR01 8 Posted December 9, 2012 Author Share Posted December 9, 2012 Cheers..It became obvious when the EGR is clogged.No engine lights or warningsFlat spot around 2000rpm around 2300rpm & all of a sudden would boost hard rather than smoothlyExcessive soot on accelerationInspection of EGR valve revealed a clogged EGR valveThis was after using Shell fuel & mixed motorway & local miles as well as occasionaly driven hard when safe to do so to prevent build up. Seems like a design fault or a common problem if ignored will cause head gasket failure due to carbon build up on the pistons. Maintenance is the key. Quote Link to post Share on other sites
