Turn Key Nothing
toyotapob
Hi all,
Just purchased a 2010 Verso 1.6 TR manual 6 speed, very happy so far except:
Sometimes when we put the key in the ignition and turn the key "nothing" all dash lights on but no start.
Penny for anyones thoughts.
I have that with my car, its something to do with the interference of abs or something and the alarm.
I find pressing the alarm button so it unlocks, then turning the key, fires up the engine.
May not be relative to your car, but its worth a shot.
Are you pressing the clutch pedal down fully ? you have to press the clutch pedal to start your Verso.
Devon
Sounds like a dodgy safety switch. On an automatic, there is a safety switch that only allows starting in Park and Neutral. In that case, wiggling the shift lever or shifting to Neutral often allows it to start. With a manual gearbox, the switch is on the clutch pedal lever.
transponsder may not be working properly. change Battery in key :)
As above, the clutch switch might not be working properly or you are not putting the clutch pedal to the floor, you have to on that model
Kingo :thumbsup:
Thanks to everyone who replied, never would have occurred to me that I have to depress the clutch pedal to start the car.
Since buying it I must have depressed the clutch on most occasions without realising, but not every time!
Any other quirks I should be aware of.
