Sign in to follow this
Slimotorious
Toyota Gone Kaput. Fuse Info
As you know i have a 1999 Toyota Avensis. Yesterday the Air Con stopped Working, the sunroof stopped working and the window dont work either and now the speedo doesn't work either.
Now where are the fuse boxes located as I have tried all 3 place and changed some fuses still no luck. Can you help please?
Share this post
Link to post
Seems a bit strange that several fuses would low at the same time. I'd also look for a wiring, connector or earth fault or something.
Share this post
Link to post
My son had this problem recently, put the car in for an Mot drove off then noticed no speedo and abs warning light on, was traced to a fuse not where you would expect to find it along with the other fuse's, but in the footwell near accelerator. He drives a Mazda but may be the same with Toyota, might be worth a look.
Share this post
Link to post
