Warning Lights On Dash, No Brake Lights, No Cruise Control
Jap Guy
Hello, Have an Avensis T4 D-4D on a 06 plate, all at the same time I have warning lights on the dash: VSC, ABS, Cruise Control, and the ! warning light is on, also the high level brake light works, but the main brake lights do not, and the cruise control has stopped working,
I have checked all the fuses, all OK.
The only thing I have found is that a thick black/blue wire going into the near side fuse box has lost it's ignition........Help
May be time to hunt out an auto electrician - unless someone can point you to exactly the right thing. You have a lot going on with your electrics it seems.
if you can check for a good earth connection. Sorry, cant be more help.
