Radio System Not Working.
jambbie
2004 Avensis. Radio stopped working a couple of days ago. Pulled and replaced the fuse but no joy. Any help appreciated.
All recent head units have 2 power inputs. One for constant memory, the other for when using the radio/CD. The general power only works when the key is in accessory mode.
On the Mk1 Avensis there are two fuses. One as mentioned for the constant memory, the second which is rated higher does the cigar lighter. I don't know if the Mk2 is different, but have a look again. Check the legends on the fuse cover and the handbook if you have one. Remember to check both fuse boxes - under dashboard and engine bay.
I did not answer earlier because I don't have any info on your car electrics.
