2007 Auris Cabin Heater Controls
indira foster
hi i have a 2007 auris the heating control just spins and wont change the temperature only blows cold air ?
i have spoken to my local garage about this they quoted me £1500 to fix this problem ???
Presumably yours has manual air conditioning. Maybe just a fault with either the knob or the back of the control panel. If like this (http://www.ebay.co.uk/itm/08-TOYOTA-AURIS-HEATER-A-C-CLIMATE-CONTROL-UNIT-PANEL-/270771915422) I would explore whether anything behind the control panel has broken
Some more detail on what Auris you have wouldn't go amiss (diesel/petrol, trim level).
hello frostyballs , it is a petrol s model manual ac manual gear change it seems to me as if a cable has broken garage say this is is a fault on this model ? but i cant find anyone with the same problem ? and the cost of the repair £1500 is a bit crazy .
yes it looks just like the one on eBay
Not come across any previous topics on the forum which would identify this as being a common fault. The description of the fault would suggest to me that something at the back of the knob or panel has broken or become detached, and the temperature isn't being adjusted.
i am in belgium working now wife tells me of this problem so i will have a look when i am home 20th dec many thanks for your help
