Starting Problem
27901591
Hi I've been having this problem for like 6-8 months. When the cars been idle for like more than 6 hours especially over night the car has problems starting.
I'll start it and it's like the Battery is dead but obviously Battery is ok. It just turns over and then drops dead again.
Anybody else had this problem?
Any suggestions?
Over read on some other car threads and also few auris ones that people have changed the glow plugs but sometimes the problem still persists.
Sounds like a new scv (suction control valve) and ecu update needed.
Just done mine with same symptoms as yours and fixed it right up...
Loads of posts regarding his issue..
Sent from my D6503 using Toyota OC mobile app
If its the glow plugs then if you stick in a diagnostic machine it will tell if it is. I doubt it since the EML would come on or the Glow plugs would light up.
