Creaky Clutch Pedal- Auris 08
Auris Girl 08
Hi
I have noticed my clutch pedal creaking like a floor board which I try to clutch control.
Whats the worst that can happen with this. Can I wait till next service early next yr and why has this happened?
It's just a squeaky pedal bit of grease on the pedal hinge will be fine after
Had the same thing happen on an Avensis 2011. I sprayed GT85 on every moving part I could find and this did the trick and the squeak never returned. DON'T get GT85 in contact with the actual pedal as your foot may slip off it. Just be very careful with the spray if you decide to use it.
I have the same problem but I try to ignore it
