Engine Wont Start When Hot (2004 Corolla)
barnett124
Hi All,
I'm having some problems re-starting my 2004 Toyota corolla 1.6l vvti and looking for some help ideas.
To explain the situation, the car starts perfectly first time if it has been left for a while unused. I can then drive the car without any kind of issues or problems and it appears absolutely fine. The problems start if I turn the car off when the engine is warmed up and attempt a re-start. The car cranks, but the engine will not start. If i then leave the car to cool down and attempt a start, the engine will start.
So far I have tried changing the Battery and installing new spark plugs, but this hasn't fixed the issue.
Does anyone have any ideas as to what could be causing this, or what I can try to fix it?
Many thanks for your help in advance.
Chris
There is a known problem with the 2.0D4D Corolla where it won't start when warm - This is due to a fault in the starter motor, and is fixed in newer replacements ones.
I wonder if it is a similar problem on yours?
Could try replacing it to see if that helps...
No warnings on the display panel. I've ordered a scanner so should be able to get some codes read by the weekend. Thanks for your help, will keep you posted!
My money is on crank sensor playing up and when it
get hot has a high resistances and it doesnt bring a code up
Just scanned it and no codes!
Also car didn't start first time now either!
Any ideas?
