Click From Drivers Front Wheel
nicebutdim
Hi, I'm getting a single click from the what appears to be the drivers front wheel on my 07 corolla
It only happens once per the following events;
Set off vigorously or lift the clutch to engine brake at slightly higher revs.
I'm thinking CV joint, DMF or wheel bearing?
There is no usual clicking on full lock when turning.
I would add lower ball joint to that list
Could also be the drive shaft, I'm having that problem now, when I am turning and taking off
