Celica Vvtli And Corolla Vvtli Engine Help
kennywku88
Depends on the person fitting it ;) ... however I believe it is the same engine so should swap yes... (I'm happy to be corrected tho)
  • 4 weeks later...
from research i believe the corrolla engine has a few bits in different places and you may need a celica TB added
