Add A Changer
Brian Barrett
I have just bought a 2000 Avensis GS TD with a standard Toyota TM4000 head unit.
I have a Blaupunkt 10 CD changer from a previous car that I was thinking of installing.
I was wondering if there is a standard output for the CD lead (the round 10 or so pin type) on the back of the TM4000.
If not, where could I get a lead/adaptor (other then dealer) and what code/fitting is it?
Also, on the Avensis, are the power and speaker fittings standard iso (clarion / kenwood etc fittings) as this may influence the choice of a handsfree kit I was thinking of installing.
If anyone has a picture of the back of the TM4000 it would be very helpful.
You will probably need an interface to connect cd changer to factory fitted head unit.
Check out:- ad-a-cdchanger.co.uk They may be able to supply interface and advice.
Thanks for the reply cogs, but I can't seem to find ad-a-cdchanger.co.uk. Explorer returns an error.
suggest trying to contact Blaupunkt themselves as most manufacturers have the option to do such things??
Sorry
Correct address www.add-a-cdchanger.co.uk
You will prob have to email them with your requirements.
Good luck
