Water Pump Locked Up
carina289
Hello
Just drove my carina back home and the multi belt just broke. Now i see the waterpump is locked (car was standing for 6 months) Is it easy to replace at home and will I not need to take the timing belt off? It's a 4A-F engine 1600
Does any one has some advice? I've had some toyota's with the 4A engine and 3sge/3sgte engines.
But now i need to do it outside (no place in garage due to projects).
I'm hoping some one can help me with some tips!
I ordered the water pump set and will have it tomorrow
Thank in advance!
Ps I will introduce myself this weekend with pictures!
Solved!
1.5hour of work, most work was removing the gasket.
Bearing was seized but now all is working just fine!
Solved!
Well done you - glad you got it all sorted. Did you change the belt and the tensioner pulley (kits were shown in link on this post http://www.toyotaownersclub.com/forums/topic/69634-carina-e-3s-fe-water-pump-change/
