front wing/fender removal(plastic panel under wipers)
eillop
After an altercation with a rock in a parking lot I need to replace the front right wing on my Aygo. To get at all the bolts I need to remove the front bumper, headlight and the black plastic panel under the wiper arm.
Is there a guide somewhere that explains how to remove the panel under the wiper?
I've already removed(broken) both clips that hold it down. I can feel the panel move but don't want to risk breaking anything. The panel itself seems to be split into two parts so I probably only need to remove one side.
Many thanks!
Hope this works...
Try;
Excellent 'how to' video posted not that long ago, should be just what you're after!
Be very careful removing the bumper. I wasn't, and I snapped the bracket off. A replacement costs about £15 but you have to remove the light etc.
