Speedometer
mcbeahm
Speedometer had been making squeeking noises for 5 to 6 years especially in cold weather. It has stopped squeeking (good :) ) but speedometer stopped working...bad :( My research shows 2 possible problems..1. Speedometer cable 2. Gear in speedometer itself.
Question: What is the procedure to getting into the speedometer box or do I have to. If I pull the cable from the trans side and its broken won't a piece be left behind?
Why is it bad that the speedo has stopped working, how often is it really used anyways....
Oops, I'll shut up, get my coat, and hide round the corner :ph34r:
Unfortunatly it will be needed for emission testing otherwise I would live without it and go with the flow
