Wheels
Woodyfjr
Hi chaps my first question.  Can anyone tell me if the C1 or the 107 steel wheels will fit the Aygo as I would prefer a spare over the inflation kit.
One can order a spare wheel kit for the Aygo, which includes spacesaver spare, tools and jack.
Thanks FB but I'm after a normal rim not a space saver but the jack will be needed.
Good Morning Chaps.  Will an earlier Aygo wheel fit a 2016 model?
I have 15" alloys but I assume the rolling diameter is roughly the same as the 14" steels.
Aygo, C1 & 107/8 of the same year are basically identical...
The wheels off a Yaris are the same too, I think?! (Dunno about the tyre size though) (and possibly the IQ too?)
Get yourself to a scrappy, single steel rim, cost you peanuts...
They might even be able to get you one that'll fit off something else, just tell them what is for... For example, I know that the PCD is 4x100, which is the same as VWs and Vauxhalls, BMW, but couldn't speak too the bore and offset matching, (though an exact match is not necessary with these).
That's what I'm after but checking the fitting are the same PCD etc.
