Piston Rings
DavidAnthony
Hi All I am looking for your information and thoughts.
I own a glanza V turbo. It is blowing blue on start up long story short I have narrowed it down to worn piston rings. It has low compression on all cylinders but there all even readings.
my Main question is seem I am getting the rings changed is there anything else needing/worth changing?
also what sort of machine work will be needed, just head skimmed?
