Remote Control Central Locking Problems
cafeg
Hello Everyone,
I've just purchased a 1996 Toyota Cavalier 24Z.
It was imported from Japan 6 months ago by the person I bought it off.
It has an alarm system on it and I have the toyota remote for it.
When I tried to use it it doesn't do anything so I took the top off the alarm remote to find it has no Battery in it.
Does anyone know what type of Battery goes into it ?
The central locking also doesn't work, when i lock the drivers door only it locks and I have to lock the passenger door seperatly.
I presume its because the remote isn't working.
Any ideas on how I can get this all going as everything is in japanese in the manuals that came with it ?
Thanks,
Steve J
usually a 12v small dumpy Battery . code 23a here in uk. also check the siren to see if it has an on / off swith for which you need a key.
Ok, Thanks I'll try that Battery in there.
Any idea why the central locking doesn't work when I use the key to lock it in the drivers door ?
most likely a circuit is disabled through the alarm wiring somewhere. electrics are
tempremental as im sure you know.
