Aygo head lamp fogged up
Chriss27
Aygo 2012 and one of the plastic casings that holds headlight has fogged up and damp on inside. Is this an issue or will it correct in warmer weather?
You probably have a crack in the light housing. Or the rubber grommet on the back covering the bulb is missing or not on properly.
take the bulb out and put a hairdryer for the hole and switch it on when its dry put the bulb back and the rubber
I have the same problem in one of the headlight in Aygo and all temporary measures (like hair dryer use, better ventilation on a dry day by leaving the rubber grommet off ) are of no use in the long run. Moisture always returns. There is a problem with water leak or the ventilation holes are blocked in the head light and getting it right by fixing them is the only way to go.
or take the hole unit out and drill 2 or 3 little holes on the backside of the unit on the underside to ventilated more
If I do nothing is it an mot failure?
