Paint damage caused by goalkeeper gloves!
Johan Damitha De Silva
My son wiped off the water/snow with his dirty goalkeeping glove leaving damage as seen on this picture? Wax did not bring back the shine. Could I use t-cut on the entire area or are we looking at a re-spray?
Looks like a perfect job for T-Cut in the first instance.
Farecla do a range of abrasive polishes if you want, say, a finer abrasive (Farecla G10, for example), but it's more expensive and not so readily available.
Not come across Farecla G10 before but this looks like the ideal product for the job. If I had owned both I presume you would then recommend G10 in the first instance?
Maguire's do two levels of cutting polish.  That should come out, even if you have to wet sand (read up wet sanding on detailing world).  Otherwise a professional detailer body shop will buff it out
