Haynes Manual Prius Uk Spec
Deet
Is there a Uk Spec Prius Haynes Manual for the 2nd Gen Prius? as I got a Manual for my just purchased 06 Gen2, I have noticed that the Haynes Manual is US spec:-
Temperature are in °F, Measurements are in Inches, Torque settings are in Ft/Ib not NM, Oil service change interval is stated as 5k not 10k like Toyota recommend and in the book the rear brakes are shown as drums not discs.
It is not a major problem but I will be returning it if there is a UK version available, Many thanks
Check the Haynes site
Cheers for that, "PLEASE NOTE that this manual is intended for vehicles built to US specifications" quite clear that.
The one I have for the Gen 2 is the same, US spec, manual number (on the front and the spine) is: 92081.
I stopped buying Haynes manuals after that one, they seem to have more refer to dealer instructions than they used to, not much help when you're a DIYer.
