Stereo fitting
Hyperkiller
Hi
I have a pioneer stereo I've got and I need to wire the parking break wire up to enable me to use some features on the stereo. Can anyone tell me if there is a easy way to bypass this or where I'm splicing the cable into location etc of handbreak wire
8 hours ago, Hyperkiller said:
Hi
You splice in here, it's just a single wire, I did mine with my Kenwood unit.
the handbrake switch normally earth out the wire
on an old kenwood tv system i had i soldered the handbrake
wire from the head unit to the main headunit earth wire
so i could have the screen on
my son used to use his playstation on it
when we went out, he was good as gold in the car.
i know someone will say " you cant do that"
so i thought i would say it first
Hows best to get the panels off do they just pull off then ?
Apparently the new pioneers have changed this so you need a on off on off cycle or something for it to work otherwise I would of done this
Here are instructions for parking brake removal, it should be enough to give you access to the wire needed.
https://www.autocats.ws/manual/toyota/auris_corolla_zze-zr-nde-ade/rm04f0e/repair2/html/frame_rm000002vhn000x.html
Cheers guys. Getting my sub installed in a few days so will ask the tech to sort it out while he has the inside stripped
Just a thought  the original stereo had settings you couldn't access while driving am I right to assume this should be the wire for the break switch too or similar ?
couldn't you fit a seperate on off switch instead of using the handbrake switch
this way the display could be used
