Lowering kits / coilovers
Junior_G
I have been able to find 35mm H&R springs for my 2014 Verso 2.0d (AR2) but haven’t had much luck sourcing anything greater than 35mm or coilovers.
Does the AR2 chassis and suspension share itself with any other models like the auris ?
I know im likely to get some grief for asking this but some guys just never grow up
thanks
As far as I'm aware the Auris, later Avensis, Corolla saloon (not the 2019 model) and Verso share the same platform.
You are correct, H&R is the only one that supplies lowering springs for the Verso. I installed them last week. Stance is perfect for me. Not too high anymore like stock, but looks a bit sportier with the 17” alloys
  • 1 year later...
On 5/26/2019 at 11:10 PM, Junior_G said:
thanks
I was wondering whether you managed to get your Verso lowered and was it worth doing?
On 9/14/2020 at 7:49 PM, zelda89 said:
I never did mate, its too chancy risk trying Auris coil overs for them maybe not too fit.
I will probably just opt for the H&R springs when the time comes and a set of 19's
