Avensis 2.2D4d Airconditioning Compressor removal
beddoes
Hi, does anyone have a manual, step by step procedure to remove the AC Compressor from a 2007 Avensis 2.2D4D. The bearing pulley needs replacing and although it appears you can purchase a replacement pulley without having to replace the entire compressor I am scratching my head on what I need to remove to get at the AC compressor and whether it makes sense to remove from below the car or above. Any help greatly appreciated as I hear it is a common problem but I cant locate any workshop manuals covering this particular engine.
Many thanks
Jon
