Check VSC and losing power
Kayleigh kay
Hi I have a Toyota verso it is coming up with check the vsc and loosing power
Hi Kayleigh, welcome to TOC 🙂
You really need to get it code read as there are so many interlinked things these days that warnings can be triggered by something that you would not expect.
P.S. it is worth putting engine/transmission details in your profile - it helps people to help you.
      This is what AA found
Patrol found the following fault code/s:System : Engine control - 15E / Engine management TCCS 1P1047 - Valve lift control (bank 1). Error Message : Circuit defective.P1049 - Valve lift control (bank 1). Error Message : Circuit defective.P1604 - Engine start. Error Message : Malfunction.Patrol tested or actuated the following component/s:Variab.valve timing sol.valve1Carried out diagnostic check Removed & refit solenoids cleared codes followed Further checks
