Squeaking clutch fork
remppainen
I have 07 Corolla E150 ZRE151, that has clutch fork squeak.
Can i just spray some WD40 or other lubricant to the fork ball just via that hole in the rubber so that i would not have to remove any parts??
WD40 or what other sprayable lubricant would u suggest?
Thanks!
WD40 is a good lubricant for seized or semo-seized components. It dries out, so not a good long term lubricant IMO.  Worth using white lithium grease in a spray like WD40.
