Bolt Size Oil Filter Plastic Housing
Ralphyee
Does anyone know the size of the bolt/screw that holds the oil filter plastic housing flap in place underneath the car as mine has worked itself loose and gone missing and the flap is now hanging down.  Toyota Corolla D4D Diesel 05 plate.  Thanks for helping if anyone can.
Have you tried your local Toyota dealer spares dept, they can usually order up the right one for you.
If it's similar to the Auris plastic under cover with oil filter flap then it's not a bolt it's a plastic push rivet, they are used all over the under body plastics and also the engine bay plastic covers..you can find them on eBay or Amazon, check the hole size with a drill as they come in variouse sizes.
