Springs
ian CLARKE
Hi. Ive recently bought an Estima Aeras 3.0 petrol 51 plate and Im convinced its got lowering springs on. Too low.  I want to change these to standard or preferably 50mm lift springs. Where wouos I get these in the UK please
Thanks Ian
Edited by FROSTYBALLS
Shouting removed
Moved to the Estima forum
Stick your head under the car and look at the springs - red, yellow or blues powder coat usually means they are aftermarket springs if they old black and crusty they may be standard
i would not raise the car over factory as it plays hell with the geometry plus a car of this age you will likely kill the bushes and tie rods quickly
Check the previous mots and see what suspension work it has had done (leaky shocks, broken springs)
https://www.gov.uk/check-mot-history
AFAIK they should be the same as the UK/Euro spec. Previa..so eBay/ECP etc.
