Help! Door window popped out of frame
Jamcal
The driver's door window on  my 54 corolla verso has jumped out of its runners so it still goes up and down but will not close against the seal.
Any ideas on what the problem is and how to sort it out?
  • 3 years later...
Hi @Jamcal. Did you ever get this fixed? Had similar happen on mine & it's one of the arms on the window regulator that bent. I've bent it back into shape which allowed me to get the window back up but I'm not risking using it anymore.
Ordered a new part from Autodoc but it's not the correct fit, despite them claiming it was, & they don't have an alternative. Just wondering if you had to have yours replaced & if you know a good source for the part?
