Prius PHV gen2 max charge rate
johalareewi
Does anyone with a Prius PHV gen2 know the maximum charging rate when hooked up to a 22kW (or even a 43kW) charge point?  My gen1 PIP can do 2.4kW/h when connected to some 22kW units but only does 1.9kW/h on my home 3.6kW charger and public 7kW chargers.
Very close to 3.5 kW/hour on my home 7kW charger.
I get a half hourly breakdown from my electricity supplier. This shows just under 2kWh for three half hour cycles, then a reduced amount on the third. Total charge from empty, as recorded by the charger, is usually just over 6kWh.
I believe it's capable of 3.3 kW max. There may be inaccuracies in smart meters and the likes.
