Sign in to follow this
Chrisb1987
Engine management light on
Hi guys n gals. I need some help and advice.
I have got a 2013 diesel yaris with 49k on the clock I bought it 4 months ago, the guy before had it from new and kept it serviced but hardly ever used the car. I have done approx 8k miles since buying which includes some lengthy runs
About 2 weeks ago my dpf light came on a day later it went out, at that point I didnt know what it was. Then my engine management light came on and has remained on since.
I have got a obd car reader and got code p2463 which relates to the dpf. And is the only code
I tried to do a long run (120 miles) I kept the revs at approx 3.5k hoping a regen would occur - I don't think it happened.
I have tried clearing the code the engine management light goes out. The dpf light comes straight on then 1 second later the engine management light on.
I have taken the car to a Halfords autocentre and got a dpf flush (£85) and full service done (£200). Picked up the car.. engine man light still on.
Tried clearing code - same issue... Halfords says I have to take car on long run... I done this no change... I appear to have gained a lot of the lost power but there is definitely still something not working properly. It almost feels like no turbo.
I have tried disconnecting the Battery (negative port only) and reconnected after 30 mins.
Before the service it was only the engine management light on... since then when I start up the car the dpf light stays on for 5 seconds before going out and leaving just engine management light on.
I really don't know what else I can do or try... I've been told I cant have a forced regen because of the engine man light.
I have next to zero mechanical expertise, and my friends have limited... so any estimates on repair costs and garages worth using in the bristol based areas would also be appreciated, I hope I have posted in the right area and given all info you require... thanks in advance
Share this post
Link to post
Did you manage to get this sorted Chris?
Share this post
Link to post
No..
I have since taken the car to a dpf specialist.
He has done a regen - 1 week later same issue
He then cleaned egr valve and done another regen.
Another week later same issue.
The engine management light is coming on whilst driving on the motorway.. it gets to the limit of requiring a regen and instead of doing a regen it puts the engine management light on.
Back pressure test was within limits
Any ideas?
Share this post
Link to post
i would say its one of the temp sensors or o2 sensors in the dpf if its not going into a regen
Share this post
Link to post
Ok thanks, I have got the car booked back in with the dpf specialist tomorrow, I will mention what you have said and I will update then
Thanks for your help
Share this post
Link to post
It could also be the differential pressure sensor
Share this post
Link to post
Not the sensors.. all the above checked
No back pressure issues
Dpf is clean but still got the p2463 code, so will have to regen to clear
Does anyone know about a possible software update? Or software issues as that is what is being suggested
Share this post
Link to post
So update...
Toyota was basically useless... tried saying it was parts all tested and checked.
Also because my software on ecu was the latest version they cant do anything
Car is refusing to regen
I'm stuck.. I've got this car it's in limp mode and nobody knows how to fix
All sensors are fine
All readings are correct and well within limits
Turbo is fine.
Egr has been checked all fine.
When driving in limp mode car drives ok just no turbo... no excessive smoke, no increased fuel usage etc.
The last couple of times had a regen done, the car was working totally fine for approx 100 miles then engine man light comes back on even when driving along (dpf light doesnt even come on).
Still getting code p2463 but toyota did also get p1608.
Any thoughts guys..  this issue is really bugging me now. And nobody is any the wiser
Share this post
Link to post
The bottom line is you need a new DPF or properly cleaned by a specialist, not the sort of thinga offered by Halford.
I have good experience of DPF issue. I used to have a Yaris from new and drives and drives on the motorway 95% of the times and at around 40k miles I noticed the DPF regenerate every 250miles then reduced to 30miles. This was reported to Toyota and they blamed the driving style.
To cut long story short, I had a replacement and a new DPF was fitted and again when the car reached around 80k miles the same old story started again. I.e. it regenerate too often and I got rid of the car.
Share this post
Link to post
Following Halfords... about a week later i went to a independent dpf specialist who has done a full dpf clean.. full checks... cleaned the egr valve fully... the dpf is clean!
Yet after having a regen approx 100 miles later it went straight onto engine man light again...
Once again fully checked.. regen took 55 attempts.
Then a week or so later same.
Turbo checked etc as well... no probs there.
Now car will not regen at all... the engine management light came on straight away whilst doing a motorway drive... no dpf light before.
Fault codes are p2463 and p1608.
Share this post
Link to post
Ok. Can you  check your engine Oil level? Every time the DPF is regenerated Diesel is gets into the engine and the Oil level raises. You might have excessive Oil level and it could trigger the engine light. Mine came on with a spanner.
Share this post
Link to post
No Oil level checked and no issue there.
Share this post
Link to post
I think you need someone to be able to read the loading on the DPF on how blocked it is. I know you said it has been cleaned, but how certain are you that the filter is not clogged?
When I had mine investigated by the Toyota dealer, they had provided me the loading values before and after the regen. It wasn't much different so they agreed that they replaced with a new DPF and that fixed the problem for another 40k miles.
Share this post
Link to post
The loads got checked by the dpf specialist. And all the sensors. The back pressure was checked... I even got that checked by toyota they agreed no issue with that
Share this post
Link to post
Loading...
