Maximum wheel and tyre size
HjortPerformance
Hi, I have a set of Gotti that I used on my old Ibiza 6k2, it is 15x7 et25 and fittet with 205/50 toyo proxes t1r. Would they fit my 2020 Aygo?
Im going to buy centerrings for the wheels to go from 57,1 to 54,1.
The Aygo is e.t 35, 205/50/15 will make the speedo read high by 1.3%
Imho 205 with will make the Aygo tram line and cause a bit of bump steer, and put strain on the rack and power steering
That was what I was thinking Also the scrubradius would be about 10% more positive.
I want to make the best of the car so if it makes it worse I am going to find a Better alternativ.
Any suggestions to bsøest fit for wheels and tires, I was thinking 15x6 et 35 with 195/50?
1 minute ago, flash22 said:
The standard ones 15" are 165/60R16
R16?
That's how tyres are measured
R = Radial
16 = is the rim size
R = Radial
Not what I meant.
R16 om 15" inch how?
The most common tyre size is 165/60/R15, with some versions (depending on market) having 165/65R14.
Yeah mine is 160/60r15.
Was thinking what et would be best with 15x6 and what tire size 195/50 or 185/50 would fit best and performe best?
Hi just a quick question I’m looking to buy alloys for my 2009 aygo does anyone know if 165/60/14 alloys will fit they are off a Honda Civic not sure what year thanks
