Car not Starting Aygo After Accident
John786
Hi ive baught a damaged aygo 2017 with passenger side airbag deployed on the front seat and curtain airbag. the car did not start. I fixed the car ive replaced the airbags and ive sent the airbag ecu near the gearstick off to get it cleared. the car is still not starting. there's power to the fuel pump just no fuel pumping out. had it started with easy start for few seconds. is there a switch I need to reset for after a accident or do I have to clear something else? Please help
Can you hear the pump prime when you turn the ignition on ? is the exhaust clear of the fuel tank ? are the seat belts free moving ?
no its not pumping fuel out of making noise at all. yes all os clear. thanks for you help im really stuck
pull the pump it may have been knocked loose, i take it you have verified the ground is good
i don't think the Aygo has an inertia switch, c/opn is controlled by the solid state  relay built into the main fuse box
have you got the correct live and not the sender, have you check the power to the EFI and pump fuses
is the fuel pump relay still present
as it may of been removed straight after the accident
for some reason
