Corolla T Sport VSC
Lordyharry8
Hello!
I have a 2003 Toyota Corolla T Sport and when I press the traction control button it doesn’t fully disable the traction control or VSC.
When the car goes into a slide (on track) the power is still cut and the brakes applied.
Does anyone know how to disable the traction control and VSC fully?
Thanks!
Harry
Moved to the Corolla Club
I think the TRC button only disables the traction control, I'm not sure if it disables the stability control also. If you needed to take this system offline completely there must be an access fuse or obviously disabling the sensors will take these offline and throw the warnings lights up on the dashboard.
  • 2 months later...
The Gyro sensor is under the passenger seat that's used for the VSC, unplug that. Will throw the lights on the dash most likely though.
