Broken axle ... or gearbox??
AlbatrosDog
So I pulled handbrake while parked and in R gear (manual gearbox Verso), something cracked/broke. Now when I start the car engine revs, the gears seem to shift normally and the clutch pedal is moving freely, but the car wont move at all - no power to wheels. It cant be the handbrake issue, because I can release it and the car can roll freely (when pushed).
Any ideas what could be the cause of it?
  • 5 months later...
Hi Kasper, sounds very much as if one of the drive shafts has failed (broken?). My nearside drive shaft just snapped when I went to move off at a roundabout.
