Changing Rear Wipe Blade 2015 Hatch
Cazzi
Hi.  I have googled the life out of it but can't find instructions on how to remove the rear wiper to replace the wiper blade! If anyone can help that would be awesome!  Cheers Caz 😀
Hi, best to buy a new wiper first, the instructions are likely to be printed on the box. Make sure you have exact same fit, take the wiper arm away from the window, set the wiper at angle and pull away from the arm, it’s very easy. Then you fit the new wiper same way, at angle and push to clip in. Job done easy.👍
There is just a T shaped bar on the blade and a half moon hook on the arm. Best to swivel the blade to one side and use the blade as a lever to get it to pop off the bar. It's very easy to do, once you have done once you will see how easy it is
