Toyota Ipsum 2004, 2AZ Engine auto transmission problems
Simon Viljoen
Good day Good people. I have a toyota ipsum 2004 model. 2AZ engine. When i take off, it leaves like its in gear 3. Then it changes on. But when it slows down like it changes from gear 3 to gear 1, sometimes when travelling slowly 40km/h there is sporadic changing of gears. What could be the problem.
You need to get the codes read, as it could be any number of issues
Have you checked the level and condition of the ATF.?
Thanks will try these options
