Gear Knob removal
NAAFI van Driver
Trying to remove the gear knob on my 2013-16 Proace 1.6 van so that I can replace the tatty gaiter. I thought it might be the same method as on the Peugeot Expert which is removal by brute force but that does not seem to work. Suggestions anyone?
  • 10 months later...
Hi buddy.... noticed you haven't had any replies
I'm trying to do the same thing,how did you get on with it in the end??
On your van according to the repair manual, unclip the base of the gaiter from the dash, pull it up over the knob, cut the cable tie retaining the gaiter, now disengage the knob
http://www.toyota-tech.eu/aimuploads/9810e9f5-a474-4118-8f7f-fdde1aa871c3/PROACE_CITY_VERSO_Shift_knob_PZ4L0_H0110_AIM_005_266_0.pdf
Cheers,thank you for the reply, I've managed to pull the gear knob off but, there's a small black plastic bit on the end of the gear shift shaft with three lugs that I can't get off, I would cut it off but only if I can replace it...so I could return back to the original knob in the future
