2021 Yaris 2 quick questions
Malcster
I am off work for a week and with dark nights drawing in I want to change the interior led bulbs
can't work out to get the interior lamp out to swap the bulbs
Also as it's the design there is now STD wiring for.under dash led does any one know of a suitable feed for a 12v pick up  that's only live with ign on
Is there anyYouTube videos for mk4 Yaris to change bulbs.  I did my Prius few weeks ago, it was tricky on the interior front light. I don’t know if yours same as mine.
Put up a photo of the light, if it’s same as mine could possibly help.
I’ll upload one tomorrow thank you
7 hours ago, trashman1965 said:
Have a look here for led lighting
Yes the dash harness is different on the design model so I need to pick a feed up from somewhere
I'll have a look on techdoc wiring harness which I don't particularly like using
Lighting, you can pick up the illumination off the back of the radio, headlights run with a switch ground
Illumination is on the 28pin
The dash harness on Dynamic & Excel models are pre wired for the 5 dash LED and the LED ( 2x each footwell 1x centre cubby part LED # 81080-33280 ) and the LED are just plug n play, the harness also runs up to the dash harness to door connection where only the Launch Edition is wired for Door handle LED inside the door.
For Door Handle you can steal the power from power window keyboard
A guy in another forum has ordered this kit for his Yaris
https://www.aliexpress.com/item/4001360550142.html
It has been designed for RAV4.  He still has not given a feedback if it works fine also for Yaris Mk 4
