Yaris mk1, are the electric mirror controls illuminated ?
Kezzy1
I'm new to having a yaris mk 1.
At night, the control switches for the wing mirrors are hard to see. I have popped out the switch and cannot see where a bulb might go.
Is the switch illuminated ?
Moved to the Yaris/Yaris Cross club.
In a word no, but there is a mod for the mk1 mirror controls iirc it uses the same part as the E110 corolla
sounds interesting.  Is it a direct swop?
I have just driven back from the garage in my mk 1 t sport , and the headlamp adjuster wheel was illuminated ,and the mirror switches were not.
Of course ,it could be that it all of that panel was illuminated originally , and a bulb or diode has gone.
And it could be the difference in specs between trim levels.
Sorry if no help, but sounds like flash 22 can sort a solution either way 😄
They are not illuminated, I can't find the info I come across a while ago - when doing the mk3 switches
This one perhaps?
12 hours ago, corradovr6 said:
This one perhaps?
And that would be my thread on the Mk3 Yaris mirror switch swap
I see a mod done on the MK1 IIRC it was a Japanese site
Oh ok. Was it written in Japanese( which doesn't really matter as long as pics are there)?
Any one interested in this mod, cost - if you have the OEM switch to rob the plug off i cant see it being more than £20 or so in parts
I am.
Just ordered a spare Corolla switch that I'll be using if it works with the Yaris connector
