Clock problem on iQ
GTRMikie
After setting the clock on my newly acquired iQ, waiting 5 seconds between minute and hour setting as instructed, when I returned to the car the following day, the time had not moved forward, it was still showing the time I had set the previous day. Can anyone explain this?
you didn't come out of the clock setting, set the hour, wait 5 sec's, set the minute and press the Mode stalk/button to exit
17 hours ago, GTRMikie said:
Thanks for that flash22, problem solved.
While we're on the problem of clocks, since I bought my used 2019 iQ, my clock has a terrible gain as to make the use of the otherwise functioning clock useless, even on the first day after adjustment.  Any ideas how to correct it, anybody?
  • Sad 1
I'm not sure if it's a generated clock or if it has a crystal, but its part of the instrument cluster, is either a repair or replace job
