Intake and Vacuum Lines.
EP91Ron
Hi there,
- So I'm installing a FMIC now and I have had to remove the stock air filter and black pipe which usually says EFI on it and feeds to the turbo.
- In the picture below you can see the blue hose that feeds off the 'intake piece' (EFI one which goes to stock air filter location) and feeds into the port into the top left just left to the cam gear cover.
- The black intake piece which has to be removed and then a shorter intake must be fitted to accommodate for the new piping for FMIC.
- So now that the black piece is going in the bin, where does the hose from the top left (next to cam cover) connect to now?
Any help is greatly appreciated.
