Hiace (tourier) Regius - Is there a suspension lowering kit available?
nesty1760
Hi All
I am looking to lower my Hiace Regius 2001 edition, is there a kit for it, has anyone done it?
do you know your model code ? eg. KCH46, KCH40, RCH42
Hi
Thanks for your reply.
It's GF RCH41W
Greddy BL comfort 14011364 50-60mm drop confirm fitment with the seller prices are all over the place (£120-210) shipping from Japan will not be cheap
I had email conversation with the seller that these springs would fit my Hiace rear only as front torsion bar
https://www.nengun.com/rs-r/ti2000-down-springs
Looks like a drop of an inch (20-25mm), would be ok, as I don't want to go too low with a torsion bar.
Would the procedure be, install the springs, then adjust the Torsion bar to match?
Yes, the torsion bar should be adjustable from the rear torsion bar mounts 1 lock nut and 1 adjustment nut, a few vids on YouTube - a good soak with GT85 over a few days will help loads with the nuts
Around the 2 min mark https://www.youtube.com/watch?v=MDU1ZW3vg7I
 https://www.megazip.net/zapchasti-dlya-avtomobilej/toyota/hiace-regius-42447/rch41-55296/rch41w-gfsqk-912799/front-spring-shock-absorber-17763562
