Replacement of weatherstrip door
RHYSF00
if you search in YouTube, perhaps Auris, Avensis or Corolla there are some helpful videos that will help you best.
Good luck 👍
6 hours ago, TonyHSD said:
Good luck 👍
I tried corolla but nothin. Would it be the same for other models? The replacement that is
Yes, they will be very similar. Even though if you look for models made before or after yours they still will be similar. Here for example this video might be helpful.
21 hours ago, RHYSF00 said:
the inside door weatherseal
Which seal do you mean ? see the pics below.
We were looking to replace the Front Door Opening Trim, the rubber seal thats attached to the body of the car , not the one on the door, but last time we checked Mr.T wanted about £120  just for the part !   Have you found a cheaper source for the trims, which ever one it is ?
001612.thumb.jpg.6a9fe3f9f0f72cade0756f9a408b9315.jpg001611.thumb.jpg.aabc081e2183078185d430c6b7c2bce5.jpg
11 minutes ago, oldcodger said:
The door seal itself. 105.55 on eBay. Only one i found
11 minutes ago, RHYSF00 said:
The door seal itself. 105.55 on ebay. Only one i found
Cannot find anything similar using that link, do you have the actual address to that part ?
https://www.ebay.co.uk/itm/360471180969?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bL3g3WGPTf2&sssrc=2349624&ssuid=7ewsefzeq96&var=&widget_ver=artemis&media=COPY
Good find, though seems they only do that one for the Corolla.
It says for a Compressor if thats what you have,  though no idea if other years / variants are different ?
You can double check the part number at these  free sites  -   megazip, toyodiy and Toyota.epc-data
I got part number from both toyota and japan-parts.eu
Also clips are coded 67867-12150
