Proace city fuse box diagram
Phillip Grimbley
Got a 23 plate, light in rear cabin doesn’t come on, anyone got a fuse box diagram for this. Found one 16-18 but only shows one fuse, the cabin interior light still works so looks like they are on seperate circuits
IIRC the Proace City is a K9 Berlingo 2018 on
The rear interior lights are usually run off the front one
Dash fusebox No.7 5 amp
I take it you have checked to bulb
The rear light has 3 bulbs, I’ve run a 12v supply through it and it works. Getting no feed to connector so must be fuse, cabin light works so must be seperate fuse which does seem strange
Anyone got answer to this, number of fuse for rear interior light, 2023 model, Toyota about as helpful as a broken hand. How hard can it be to know the fuse number
It's Toyota by Badge only, i will see if i can find a diagram - i think you will find it's on the same circuit as the front one - i take it you have had both lights out and checked power using a ground on the body (not the fitting/light)
My mistake, i meant Citroën Berlingo K9 aka pug Partner/Rifter
https://imgvehicle.com/citroen/berlingo-iii/fuse-box
https://car-box.info/fuses-peugeot-partner-b9-2008-2021.htm
As i posted above Dash fusebox No.7 5 amp
  • 10 months later...
Hi Philip did u find the solution to this problem I have same problem and can’t find the fuse
