I was very lucky
RHYSF00
So i decided it was time to check my brakes and wheels. Had a sound 2 weeks after renewing brakes a while back. And a slight knocking apparently.
Came home from work. The noise was very lound and i decided time to jack and look. And it turns out there was slight heat damage to the back of the pad and a bolt not tight,Caliper bottom bolt, so i cleaned ut all. And greased where there is metsl to metal contact and removed a peice of shim. Went on a test drive to get coffee and. I seem to fixed it.
Thought i share this story. Always check your nuts.
Just remember, the most dangerous nut on any car is the nut which holds the steering wheel
  • Haha 2
Didn't know that
  • Haha 2
Yes, the nut that holds the steering wheel makes some stupid decisions sometimes, which lead to accidents. The same nuts also drive like idiots 😁
  • Haha 2
I see those idiot nuts every time driving on greater London roads.
  • Haha 1
