Low Tyre Pressure Warning
Jahonny
On the new Aygo X, how do you remove the low tyre pressure warning sign on your dash. Tyres are checked and fine but the warning light won’t go off and can’t find a way to reset?
Hi John, on my RAV4 it's reset by going into the vehicle settings menu and choosing TPMS reset pressure option. Maybe a similar method on your Aygo.
This reset / setting can be accessed by pushing arrow down on the left side of the steering wheel until you go into the 'vehicle settings' part (use OK button)...
The manual tells me it's called TPWS at Toyota. When you access this setting, go to 'setting pressure', then press ok until the warning light for TPWS blinks 3 times...
Reset is done.
*TPMS tyre pressure MONITORING system
 TPWS tyre pressure WARNING system
On my Yaris I just reinflated the tyre showing soft and it disappeared after driving a couple of hundred yards.
