Landy Wheels And Tyres
kalakuta
Can I swop my 265/65/17s for 286/65/17s for 285/65/17s with no problems associated
The speedo will over read by 1mph at 30 and 2 mph at 60 the tyre is also wider and taller by 20mm
As you can see in the chart below, changing from 265/65R17 to 285/65R17 will raise the gearing by 3.3%. It will also increase the radius of the tyre by 13mm.
Most speedos over-read by up to 5% on standard tyre sizes, so fitting slightly bigger outside diameter tyres can actually make the speedo more accurate.
It's easy to check by using google maps, which now has a GPS speedo built into the app.
If you're currently doing 29mph and 58mph when you're speedo is showing 30mph and 60mph, the bigger tyres will make your speedo reading spot on.
Outside diameter of tyres
265/65R17 776.3mm
285/65R17 802.3mm (+3.3%) (26mm increase in diameter, ie. 13mm increase in radius)
Yokohama G015 Geolandar AT (All-Terrain) 3PMSF (winter rated/all-season tyre) 285/65R17 116H
Yokohama Tyres / Car / Yokohama G015 Geolander AT Yokohama G 015 285/65 R17 116H TL click to zoom imagehttps://www.camskill.co.uk/m54b0s13110p164210/Yokohama_Tyres_Car_Yokohama_G015_Geolander_AT_Yokohama_G_015_285_65_R17_116H_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_A_Noise%3A_71dB
Yokohama Geolandar A/T G015 4 x 4 Tyre
Lifetime Guarantee on this tyre
Yokohama tyres
285/65 R17 H (116)
Product description & features
  • Strong traction
  • All terrain 4x4 tyre
  • Longer mileage
The Geolandar A/T G015 is an all-terrain 4x4 tyre, designed for strong traction in all condition. It features an ‘Enduro Compound’ that was created to encourage off-road robustness and resistance against damage.
The tread pattern of the Geolandar A/T G015 two different types of grooves – circumferential grooves and edgetec grooves. The circumferential grooves have been designed to deliver excellent water evacuation in order to reduce aquaplaning, whereas the edgetec grooves have been designed to create more cutting edges to increase traction in winter conditions.
To increase confidence in the all-season traction, the tread pattern also includes triple 3D sipes that change shape as the tread wears to maintain biting edges at all point in the tyres lifetime.
All Season Tyres
What is an All Season tyre?
Designed to cope with all sorts of conditions - good performance delivered throughout the year. Moderate natural rubber content to stop the tyre hardening in temperatures below 0 degrees Celsius – enhancing grip. Designed with moderate tread depths that have been engineered to help deliver a longer tread life than many summer tyres
How can I tell an All Season tyre performs in winter weather?
This tyre features the EU sanctioned 3PMSF marking - Three Peak Mountain Snow Flake:Three Peak Mountain Snow FlakeThis accolade was introduced to be an easily recognisable symbol which displays that the tyre has passed rigourous tests to prove it is suitable for driving in winter weather. It confirms the winter suitability of a tyre.
Are All Season tyres suitable for the UK?
Given that the UK suffers from moderate and interchangeable winter conditions - with severe ice and snow becoming uncommon for much of the country - this makes all season tyres a very good choice for our roads. As they are able to cope with these conditions very well.
Do I need to swap my tyres throughout the year?
Given the nature of all season tyres, which can perform equally well in the summer months and the winter months, the need to replace tyres depending on the seasons is not required when all season tyres are fitted.
Main Product Image
https://www.yokohama.eu/en/G015/?tx_tyre_pi1[diameter]=17&tx_tyre_pi1[index]=116&tx_tyre_pi1[ratio]=65&tx_tyre_pi1[speed]=H&tx_tyre_pi1[width]=285&cHash=10cca7384b7d98fe24b8839344b16dc4
