"Klonky" sound from left front wheel solved 😀
HSDish
There was a massive " klonky" stund from left front wheel , when drivning ower bumps.
My Toyota garage found this pebble ( about 25mm / 1 inch diameter) clamped att the attatchment of the link arm. 😮
  • Like 3
Glad it’s sorted. I had a similar issue when I had one of my Yeti’s which turned out to be a stone jammed between the offside disc brake cover and the disc, boy did it make a racket.
I had the same on my Metro, at least I found it quickly enough to not cause any damage
