Balancer Shaft Bearings Needed - 12/1996 Camry
Jed P
Hello, am sorry if this is the wrong place to post, I am trying to find spared for my brothers car, and posted in the Camry section, and no comments yet... I am trying to find part numbers or the spares themselves.
The Camry Forum Post is here
Extract is below, and pictures are on the original Post, thanks in advance for your help 🙂
  • Half Shell Balancer Bearings
  • Set of 12 I believe (may be split sets for grooved+non grooved)
  • 8 Plain, 4 Grooved
  • Engine 5SFE 2.2 litre - Manufacture 12/1996 5S-FE 2164 & Full number on plate SXV10R-AEBEKH - VIN AHT 53SK1009520723 (Built in South Africa)
  • 5000th of an inch oversized needed
  • Balancer unit above sump
  • Bearing diameter 29mm inner less 5000th inch oversized, outer 32.6mm
